Quick overview
This workflow scans Reddit (via Google Custom Search), Twitter/X, and an RSS feed every 15 minutes for buying-intent posts, enriches and scores leads with Apollo, OpenAI, and Anthropic, queues drafts in Airtable, and routes human-reviewed outreach through Slack, with optional Gmail sending plus nurture, reporting, competitor monitoring, and
- Runs every 15 minutes to search Reddit (via Google Custom Search), Twitter/X (recent search API), and an RSS feed, then normalizes the results into a common lead format.
- Checks Airtable to deduplicate by source URL, then uses OpenAI (GPT-4o) to score buying intent and drops low-intent noise.
- Saves new leads to Airtable and enriches each lead using Apollo (if an API key is available) or a Google search fallback, then uses Anthropic Claude to build a buyer profile and calculates a weighted total score.
- Creates outreach drafts using a multi-step OpenAI + Anthropic flow for HOT leads (strategy, message writing, and spam/quality validation) or a single OpenAI draft for WARM leads, then saves the drafts to an Airtable outreach queue.
- Posts the lead and draft variants to Slack #lead-review for human approval, then sends approved emails via Gmail with a randomized delay or posts ready-to-send copy to Slack for manual Reddit/LinkedIn outreach.
- Runs a daily nurture sweep that decays lead scores in Airtable and uses OpenAI to decide whether to follow up, change approach, wait, or archive the lead.
- Runs a competitor scan on a schedule to find Reddit complaints via Google search, scores opportunity with OpenAI, and saves qualifying leads to Airtable.
- Posts a weekly pipeline report to Slack #lead-analytics using OpenAI-generated insights, while a global error trigger logs failures to Airtable and alerts Slack #lead-alerts.
- Create an Airtable base with the tables and fields referenced in the workflow (LEADS, OUTREACH_QUEUE, INTERACTIONS, ANALYTICS, COMPETITORS, SHADOW_MODE_LOG, and ERROR_LOGS) and update the base ID/table names to match.
- Add credentials and replace placeholders for OpenAI (YOUR_OPENAI_KEY) and Anthropic (YOUR_ANTHROPIC_KEY) used for intent scoring, profiling, drafting, validation, nurturing decisions, competitor analysis, and reporting.
- Set up Google Custom Search (API key and Search Engine ID) and update the Google Alerts RSS feed URL (YOUR_ALERT_ID) used for scanning Reddit via Google and monitoring RSS.
- Provide a Twitter/X API Bearer token (YOUR_TWITTER_BEARER) for the recent search endpoint.
- Connect Slack credentials and ensure the channels #lead-review, #outreach-ready, #lead-analytics, #shadow-mode, and #lead-alerts exist.
- Connect Gmail OAuth2 credentials and ensure leads have an email address available before enabling automated email sending, and optionally set the APOLLO_API_KEY environment variable and replace YOUR_APOLLO_KEY to enable Apollo enrichment.
